pasteclip command not working with script in accoreconsole
ottosson_mathias
ottosson_mathias
I'm trying to write a script with the pasteclip command and then run it in accoreconsole on some files.
It seems to work when I have copied elements from AutoCAD, although not guaranteed. But when I have just text in the clipboard it never works. It does work to run the command manually in accoreconsole but not from a script.
The script can look something like this:
pasteclip
0,0 (for text, or 0,0,0 for AutoCAD elements)
qsave
That's it. Nothing magic.
Is there a security aspect that's stopping me from pasting things with pasteclip in a script or why won't it work for me?
VincentSheehan
Are you copying the entities from the dwg to where you are pasting them?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
ottosson_mathias
I have had more success when copying from a dwg file, but if I remember correct I have seen this fail too. I'll check this again.
I am however never able to paste text. Like copy some text from notepad and paste it with pasteclip. But it does work when running accoreconsole and typing pasteclip manually (no script).
