AutoCAD Forum
SNAP VS X,Y COORDINATES
2 REPLIES 2
1043 Views, 2 Replies
I know there is a way to turn off the x,y feture and move an object to a snap corrdinate. right now I try to move an obect, line, whatever, and when I touch and highlight the move to object and hit the TAB key instead of toggling through my snap options it toggles between x and y coordinates.. and when I start a new line and highlight the object the line will start from again it only takes the closest snap endpoint or center point and when I hit the TAB key it toggles between x,y coordinates. want it to toggle between snap points. please help
2 REPLIES 2
nestly2
Make certain OSNAP is turned on (F3 or the status bar toggle) and make certain you have the Object Snaps you need checked
I assume you are talking about Dynamic Input? You can toggle it by clicking the bottom toolbar or by hitting F12.
