Single line text prompt
AutoCAD 2016
After i click single line text command it prompts me to " Specify first endpoint of text baseline" then i click again and it prompts me to "specify second endpoint of text baseline". theres no option of "specify a start point" which is what its supposed to do.
When I do this the text does not come out right as it is squished within those parameters. I cant figure this out, and i see no solutions.
Paul_Gander
@Anonymous wrote:
...theres no option of "specify a start point" which is what its supposed to do. When I do this the text does not come out right as it is squished within those parameters. I cant figure this out, and i see no solutions.
You need to have the command window switched on and several lines of command history showing (permanently). Type COMMANDLINE or press ctrl+9. That will show you your current settings and options. You currently have text justification set to FIT or ALIGN which is why you are being prompted for 2 points. Instead of picking the first point use the JUSTIFY option to select a different setting. Press F1 after starting the TEXT command for an explanation of the justification options.
Alfred.NESWADBA
I agree with @Paul_Gander that your default text justification is set to FIT or ALIGN.
You can change this, as already mentioned, during the command _TEXT, you can also set the sysvar TEXTJUSTIFY to set the alignment to a new default (>>>details<<<).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
thanks for the swift response.
that did it.
rage avoided.whew
