Message 1 of 10
Significant digits.
I use AutoCAD 2017 everyday. I am also learning Fusion360. Sometimes I generate a 2D drawing in 360 and save it as dwg. In AutoCAD, I open it and Exportlayout so I can use it to make measurements.
By default, it gives the results in 1 or two significant digits. I now have to cut and paste the drawing in another file because Precision only changes the values selected and if you make more measurements the door is open for mistakes.
How do I change the default parameters to 4 digits with trailing zeros? I want to change it once and forever.
Also, how does one change the same default parameters in Fusion360? Once and forever.
