Ribbon Behavior modification
peells
Message 1 of 15
peells
I would like to change how the ribbon acts when I select an object, I want the ribbon to stay on the home tab until I want it to be on a different tab that I manually select. Is that possible? The reason for this is because I almost never want the selection AutoCAD comes up with for the Ribbon Tabs (it is Impossible for it to predict what I want and it is NEVER correct) I usually just want to check what layer something is on only or I am going to view its properties the Ribbon constantly changing when I am working on an object really cuts into my production as I am constantly having to switch the ribbon back to the home tab which is exactly where I would like it to be at all times.
Accepted solutions (4)
Replies (14)
Message 2 of 15
john.vellek
Hi @peells,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I do not believe there is any way to defeat the context-sensitive menu.  Perhaps though utilizing the properties palette would help to alleviate some of the behavior you describe.
John Vellek
Message 3 of 15
pendean
Community Legend
Community Legend
Dock the PROPERTIES palette and use it instead.
Message 4 of 15
cadffm
change the focus of your contextual tabs to 'full without focus',
so you have access to all contextual tabs, but the focus still on the current tab.
Example for selected (DWG) Xref.
Sebastian
Message 5 of 15
cadffm
For Layer information i would use the LAYER option in QAT (QuickAccessToolbar)
or usual toolbars.
command: -toolbar
LAYERS (and perhaps also PROPERTIES)
show
Sebastian
Message 6 of 15
pendean
Community Legend
Community Legend
That's it: nice tip.
Message 7 of 15
gotphish001
Another tip based on that good tip. Go in and make the layer drop down wider. Then you can see all those long layer names without them being cut off and without clicking on it. I went in and kept adjusting the width until I could see the full name of my layer with the longest name.
Nick DiPietro
Cad Manager/Monkey
Message 8 of 15
cadffm
And for users with 2014 and older: RibbonContextSelect
http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ff-4f542f6211c68d07b4a-775d.htm
Sebastian
Message 9 of 15
pendean
Community Legend
Community Legend
I knew about the width/size option 🙂
But I can add to your tip: I use this code for Width instead of a strictly defined digit as written
NaN
It allows for resizing when for example the REFEDIT ribbon buttons show up.
Message 10 of 15
john.vellek
HI @peells,
I am coming back to your thread to see if the issue or question you posed has been resolved from the many great answers provided..  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
Message 11 of 15
peells
Thank you this seems to help and thanks for the screen shots it made finding how to do this easier
Message 12 of 15
peells
This works!! My ribbon now stays where I left it before I clicked on a hatched object, or an xref, and it should work for other items reacting the same way as these. When you find something you do not want the ribbon changing from the home tab by random selecting of objects.
Message 13 of 15
Penava
Message 14 of 15
cadffm
Sorry.
Help me to write it in english well, because it seams that my words wasn't clear enough.
"for users with 2014 and older: RibbonContextSelect"
Sebastian
Message 15 of 15
Penava
Not sure if smart or just British
