Message 1 of 15
- Mute
- Permalink
- Report
I would like to change how the ribbon acts when I select an object, I want the ribbon to stay on the home tab until I want it to be on a different tab that I manually select. Is that possible? The reason for this is because I almost never want the selection AutoCAD comes up with for the Ribbon Tabs (it is Impossible for it to predict what I want and it is NEVER correct) I usually just want to check what layer something is on only or I am going to view its properties the Ribbon constantly changing when I am working on an object really cuts into my production as I am constantly having to switch the ribbon back to the home tab which is exactly where I would like it to be at all times.
