AutoCAD Forum
SHX fonts converting to TXT
3 REPLIES 3
743 Views, 3 Replies
I am having a problem where my SHX font is reverting to TXT. It only happens in some of my drawings some of the time and I cannot find a way to fix it. I go into the font manager and the right SHX is assigned to the text style but it keeps showing up as TXT. I am running AutoCAD 2016 on Windows 10.
Tags (1)
3 REPLIES 3
john.vellek
Good morning scottadm,
Welcome to the Forums!
Your problem sounds like a SHX file is missing or damaged and is therefore getting substituted. Can you open your text Style Manager window and take a screenshot of a couple of the styles that are exhibiting this problem? Yellow triangles next to the style indicate that a font is missing from your system or that it is damaged.
I look forward to helping you work through the problem.
John Vellek
pendean
Open STYLE command: look for text styles with a yellow triangle next to the font name, these are missing. Are those the txt ones on screen that you see?
john.vellek
Hi scottadm
I am checking back to see if you were able to resolve your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
AutoCAD Inside the Factory
