10:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using AutoCAD 2018 and I am having problems with the shortcut menus. I have customized the default and the edit shortcut menus
within the CUI. But I cant get it to show the correct one when I right click inside the drawing area. when it should be using the default one it is using the edit. Actually it uses that menu for both. Any ideas. I have no problem with them in AutoCAD 2017. 2018 Is setup the same way.
Thanks in advance
Ken Baker
