Sheetset : Moving the .dst file
cyberflow
Advisor Advisor
Message 1 of 26
cyberflow
I actually started a DST file in another project folder that doesnt concern the drawings.
All the drawings (Or sheets) are in the good directory.
But the DST isn't in the good directory.
I tryed copying the dst, but at the end i get a msg that the link isn't ok.
So how can i move the DST with out reimporting and checking if all my sheets are ok with this change ?
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Replies (25)
Message 21 of 26
cyberflow
@Edwin.Saez : I tried the steps that @Cadologist suggested me and didn't work. I think you don't understand my issue and what i'm trying to do. It's ok, no need to debate and thanx for suggesting, i really appreciate it.
@Cadologist : I've tryed something today, seems pretty simple.
So i've deleted the old DST in the old Folder location so it won't link to it.
But before i've simply copied the DST into the new folder location.
Opened the DST from it's new location.
Then afterwards, i've opened each file one by one thru the sheetset (The DST in the new location).
Each time i've opened a drawing, i've validated if the DST affiliated with the DWG was the correct one thru SSFOUND and since i've opened the drawing with the DST on its new location it updated the parameter in the DWG file.
Solution was pretty simple.
Hope this helps someone 🙂
Thank you guy's really appreciated for your help !
Frank Freitas
LinkedIn
Message 22 of 26
Cadologist
Great to hear cyberflow, I'll bookmark this one myself and give that workflow a try next time I run into a similar issue!
Chad Franklin
Message 23 of 26
cyberflow
Sure do !
And keep me posted if it works too 🙂
Frank Freitas
LinkedIn
Message 24 of 26
prousseauCQJ6U
Hey, i had the same problem and your solution worked miraculously. Thanks for the detailed guide!
Message 25 of 26
how to  save the autocad file to  .DST Format
Message 26 of 26
ChicagoLooper
The .dst format refers to a Sheet Set.
To create a Sheet Set, to this:
Go to Application Tab (Big 'A' top left corner)=>New=>Sheet Set. Follow the prompts to create a sheet set.
Chicagolooper
