Something is wrong with the pdfs that I have been publishing from Autocad using sheet set manager. For some reason the thumbnails for the pdf, for each page, are the name of the first page in the file, instead of what each sheet is labeled. I can't find the setting in which this changed this. In my office, everyone is using the same override export to pdf settings but only mine has a problem with naming. Please see image below to what I mean. The bookmarks are correct.
The issue doesn't look like a problem with thumbnails so much as the names listed on the thumbnails.
When you say you are the only one having the problem, have others tried publishing your sheet set?
If you try publishing without book marks does it make a difference?
CADnoob
Make sure you have the latest update.
@kvavilov wrote:... I have been publishing from Autocad using sheet set manager.
... everyone is using the same override export to pdf settings but only mine has a problem with naming.
Please compare those settings and share the images.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
