Sheet Set Manager- View labels w/ automating view label data
1miguel
1miguel
Im trying to transition into using the ssm, but the fields for the label blocks has me stumped. I'm following the Mastering AutoCad Sheets - an expert guide pdf.
When I place a model view, the view number and view title are not showing what  i want, the scale info comes in fine (see image below). The view title is taking the name of my model view and the view number is coming in as dashed lines.
On the template where the ssm is getting the block info from, The view number is set to SheetSetPlaceholder/ViewNumber/None . The view title is set to SheetSetPlaceholder/ViewTitle/Uppercase
I would like the view title to match my sheet title which is a custom sheet property and the view number to populate automatically every-time i add a viewport to a sheet.
natasha.l
Hello @1miguel
To verify that the values are set up properly, please take a look at this video. Make sure to use the proper dialog window to adjust the attribute definitions.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
1miguel
This helped, thanks.
natasha.l
Hello @1miguel
That's great to hear. Thanks for posting & we hope you continue to support the community by contributing! 😊
