Scale in layout
Scale in layout
Scale in layout
Hello, can someone help me with a scale issue. I am working in arch units and when i go to layout it is very small on an 17x 11 and should be a lot larger. When my teacher had it scaled it worked perfectly and now mine is not working
TheCADnoob
You can change the scale of your paper space. Double click in your paper space to activate it and then change the scale on the bottom right.
2398847f-1bdf-48a1-a1e8-d4441a8a2ec0,640,620
CADnoob
GrantsPirate
Your layout border is not 17x11, erase and draw to proper scale, create a viewport inside that area, set the desired scale.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
TheCADnoob
I created this screen cast and put it in my other response... but it looks like it never made it through the posting..
CADnoob
