- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Im trying to transition into using the ssm, but the fields for the label blocks has me stumped. I'm following the Mastering AutoCad Sheets - an expert guide pdf.
When I place a model view, the view number and view title are not showing what i want, the scale info comes in fine (see image below). The view title is taking the name of my model view and the view number is coming in as dashed lines.
On the template where the ssm is getting the block info from, The view number is set to SheetSetPlaceholder/ViewNumber/None . The view title is set to SheetSetPlaceholder/ViewTitle/Uppercase
I would like the view title to match my sheet title which is a custom sheet property and the view number to populate automatically every-time i add a viewport to a sheet.
