Sheet set manager not allowing new sheets
Hello-
I am using AutoCAD 2017.  When I set up a new sheet set, the sheet set manager won't let me add new sheets to a set - all the options are greyed out when I right click on it.  I can still view and access sheets created by others in my office (who are using earlier versions of AutoCAD), but I can't add new sheets to any sheet sets, old or new.  Solutions?  Thank you!
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I wonder if this is a permissions issue. Have you tried creating the sheet set in a different location? Are you an administrator on your workstation?
John Vellek
Hi John-
There are no problems creating sheets on other computers in the office, but they are all running earlier versions of AutoCAD. I will check into the permissions thing, thanks.
Paul Cady
Landscape Designer / Horticulturist
Richard Hartlage Land Morphology
1512 Alaskan Way
Seattle, WA 98101
D 206.576.0438 O 206.443.2120
www.landmorphology.com
john.vellek
Hi Paul,
By different locations I meant such as on the local C: drive as opposed to a network folder.
Did the permissions issue seem to have any impact?
John Vellek
No, but then I restarted my computer and it worked. So...no real answer I guess. But thank you!
Paul Cady
1512 Alaskan Way
Seattle, WA 98101
jnarcisse
I created a new sheet set. However I can t add a new sheet to the set as all the menu items are grayed-out when I try to select new sheet command while right-clicking on the sheet-set name
