Shadow-Rendering
Shadow-Rendering
Shadow-Rendering
Hello
I use autocad 2018 and I often render 3D images.  The problem is that the shadows are too dense, too black. Is there a way to set the density of shadows in this type of rendering?
The white text will not come out the right color also, how to adjust?
Thank you for your reply.
WarrenGeissler
In AutoCAD you're limited to the render environment settings for lighting / shadow control, and that is just for the lighting effects you want. If you want greater control over your render scene you can try to render in the cloud. The render environment settings also control the white balance of your lighting. That is what is most likely affecting your text.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
j.palmeL29YX
Try SKYSTATUS=2, this brings more light at the dark (the shadow) side 😉 . (PERSPECIVE must be 1).
cadder
Jürgen Palme
j.palmeL29YX
White faces will never be really white in an (ACAD-)rendered image.
Try this workaround: Convert the Text to faces (explode text and then create regions or extrude a little or any similar way). Then attach a self illuminating material to the faces.
HTH
cadder
Jürgen Palme
j.palmeL29YX
And here a screencast how I'd do it.
https://autode.sk/2rid6fT
cadder
Jürgen Palme
