AutoCAD Forum
setting property
11 REPLIES 11
Message 1 of 12
andre_andre168
741 Views, 11 Replies
setting property
hi
i am new to autocad, pls help
i want to know how to set the property as picture number 1, currently is like picture number 2. that is a property of a line, i got from 2 diff files.  thank you
regards
andrepic 1pic 1pic 2pic 2
11 REPLIES 11
Message 2 of 12
@andre_andre168 ,
Welcome to the forum!
For Picture 1, draw a Polyline.
For Picture 2, draw a Line.
If currently a line, just use PEDIT to make it a Polyline:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 3 of 12
tyvm,
i use DIST, but how come the result is diff for the same line as shown on the pic. the correct distance is 19.2221, also the elevation is not 0
regards
Message 4 of 12
cadffm
in reply to: andre_andre168
0. Without your data, everyone have to guess only
1. You don't select the same point (see your osnap Icon), so that it is possible the problem (without your data, can't know that)
2. The main reason  will be different heights.
The DIST distance value refers to the distance between the points, not the projected distance on the view plane.
Share both objects (.dwg) and we show you the facts
Sebastian
Message 5 of 12
@andre_andre168 ,
Consider using the FLATTEN command, or change the Z value to 0.
That usually happens when you have different "Start Z" or "End Z", as your sample shows:
Emilio Valentin
Message 6 of 12
andre_andre168
in reply to: cadffm
hi, ty
this is exactly in the same file and the same spot
andre
Message 7 of 12
hi
ty, yes, i think this is the problem, how to change z value to 0. i already read the link, but not all z become 0 when i use a command as below
Alternative to change the Z value of objects to zero
Use the CHANGE command:
  1. Type in the CHANGE command.
  2. Type ALL to select all objects and then Enter.
  3. Type P for Properties.
  4. Type E for Elevation.
  5. Type 0 and then a final Enter to end the command.
andre
Message 8 of 12
cadffm
Same file, okay
Same spot, NO it isn't.
Not the same Snap-Point. Just the same X and Y-position, but not the same Z-position.
Share the part of your DWG and we can show you what you are doing and why it is differently.
Sebastian
Message 9 of 12
@andre_andre168,
As @cadffm mentioned, share your file for everyone to provide you better answers.
Note: Make sure to FLATTEN any reference files (if any).
Emilio Valentin
Message 10 of 12
hi, ty
@Valentin-WSP
@cadffm
here is the file
andre
Message 11 of 12
@andre_andre168 ,
As mentioned before, use the FLATTEN command (while on TOP view).
After using the FLATTEN command:
Emilio Valentin
Message 12 of 12
it solved, tyvm
andre
AutoCAD Inside the Factory
