setting dimension style
when create a dimension, the text is hidden but the line is still there....what should i change at dimension setting?
Alfred.NESWADBA
I guess the text is not hidden, just to small to see it. Are the arrows also "hidden"? If so change the dimension scale, if the arrow is visible then another option might be that a textstyle is used with a too small textsize (not set to 0.0).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I already setting the text height...the arrow still there.when double click
at the dimension the text show up. But when normal the text does not show.
Alfred.NESWADBA
have you looked to the TEXTSTYLE and the height set in the textstyle?
- alfred -
Alfred NESWADBA
Done and settled. Thank you
