setting a viewport color has no effect
mikegera
mikegera
First, I know I've been posting a lot of questions lately.  Thank you so much for all the help, it's greatly appreciated.
In the attached .DWG, the DIM layer color (for example) is set to yellow in model space and set to "8" in paper space.
However, in paper space, it still appears yellow.
What am I missing?
Thanks.
cadffm
>>"However, in paper space, it still appears yellow."
But draw a circle in paperspace and you will see - it works there!
>>"What am I missing?"
You changed the color for another viewport - the system paperspace viewport
If you like to change the VP COLOR of a userdefined viewport, you have to go INSIDE the viewport!
Command _MSPACE or doubleclick in the middle of your viewport.
Open Layerproperties-Manager and change the viewportproperty "VP COLOR",
jump back to the Paperspace by doubleclicking outside the viewport area or by command _PSPACE
=> and change the VP COLOR for your paperspace back to normal.
While in paperspace, change the VP COLOR settings..
Sebastian
pendean
Community Legend
Community Legend
@mikegera
Nothing is "set to 8" inside your layout's VIEWPORT (get it, you actually have to be inside a viewport to set the column VP, which stands for ViewPort)
But now it is an you get what you crave
Also, your viewport is not set to an actual scale, and it is not locked. Two other problems you'll probably come back to ask about I suspect.
mikegera
Ah, that was it, thanks!
Wow, that is one of those things where if you don't know it...
