AutoCAD Forum
Setting a path
1 REPLY 1
230 Views, 1 Reply
Setting a path
While working on a project through Projectwise in AutoCAD 2018, I have come across an issue setting the path for an xref I am using.  Every time I open the sheet, I am asked to set the path to the Xref.  After doing this, saving the work I have done, and then checking the drawing back into Projectwise, I am asked to repeat the same steps again when I open the sheet back up.  How do I fix this?
1 REPLY 1
pendean
Ask ProjectWise support, that's a known limitation unless they have a fix https://www.bentley.com/en/support
Forma Design Contest
AutoCAD Beta
