Set linetype scale in layer properties amanger
jmvogt1986
Message 1 of 17
jmvogt1986
Greetings fellow Jedi 😎🤝
PREFACE:
One can set the lineweight/thickness  from the layer properties manager. For the purposes of this example and screen shot I have set the lineweight to 0.2mm.
 So now any object/line etc will have a lineweight of 0.2 (unless you manually change it from the properties palette).
I assume that by default line type scale is set to 1?
QUESTION
  1. I would like to know if there is a way/option to set the linetype scale to achieve the same thing as setting the lineweight like I mentioned above?
(MSLTSCALE and PSLTSCLAE are set to 1)
  1. I have set the linetype scale to 0.1 from the properties palette. Now does this mean that the 0.1 line type scale setting will apply to all line types in this dwg?
  2. Is there another way perhaps throm >DIMSTYLE?
Replies (16)
Message 2 of 17
Kent1Cooper
  1. I have set the linetype scale to 0.1 from the properties palette. Now does this mean that the 0.1 line type scale setting will apply to all line types in this dwg? ....
Yes to both.  Unfortunately, there is no way to assign different linetype scales to different Layers.  But you can assign different linetype scales to objects.  So you can, for example, isolate a Layer, select everything on it [or do so in QSELECT without isolating it], and change the linetype scale of all the objects on that Layer in the Properties palette, all at once.
Kent Cooper, AIA
Message 3 of 17
jmvogt1986
Alright thank you, it is a pity though you can't do it by layer hey?
Message 4 of 17
Kent1Cooper
You can put in a request for that kind of option at the >Product Feedback Forum<.
Kent Cooper, AIA
Message 5 of 17
kristiL539J
The linetype scale is set in the layers box. When I go to plot, I use to be able to (in release 2018) see the different thicknesses of the lines. Now that I have switched 2023. The plotter or AutoCAD does not recognize this. I need some help please
Message 6 of 17
TomBeauford
The linetype scale has never been set in the Layer Manager.
You should be able to see a polyline's width in 2018 or any newer version.
To see the lineweight of a line LWDISPLAY must be set to 1.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 7 of 17
Kent1Cooper
@kristiL539J wrote:
The linetype scale is set in the layers box. When I go to plot, I use to be able to (in release 2018) see the different thicknesses of the lines. ....
As @TomBeauford said, linetype scale is not set in the Layer Manager, but it sounds like you may mean lineweight, which is a property of Layers.  You can turn on/off that LWDISPLAY System Variable in the status bar:
Linetype scale can be set for the drawing, but also individual objects can have override values for it, via the Properties palette, a CHANGE command's Properties option, or a CHPROP command.  Lineweight of individual objects can be overridden from their Layers' setting in the same ways.
Kent Cooper, AIA
Message 8 of 17
kristiL539J
The linetype thickness is set in the layer box. When I printed/plotted in 2018, you could see the thicknesses. When I plot in 2023, all lines are the same thicknesses. Is there a change in release 2023 that will not let the line thicknesses show or plot?
Message 9 of 17
TomBeauford
Lineweight was added to the Layer Manager in the 2000 version, before that lineweight was controlled by your CTB file. There has never been a Thickness column in the Layer Manager, let go of that.
Many still use an CTB or STB with lineweight assigned to colors or plot styles.
Maybe you're using a different CTB or STB now than the one you were using with 2018?
2023
Message 10 of 17
Kent1Cooper
@kristiL539J wrote:
The linetype thickness is set in the layer box. ....
Please use the right terminology.  There is no such thing as "linetype thickness."  What you're talking about is lineweight [the heading at the top of the column in the Layer Manager tells you that].  Linetype is about continuous vs. dashes-and-gaps-and-dots patterns vs. text/shape inclusions [a linetype can have both dash/gap/dot pattern and text/shapes].  Linetype scale affects the sizes of those elements [dashes, gaps, text/shapes] only in non-continuous linetypes.  Thickness is up off the page, in the Z direction.  Width is a characteristic of Polyline segments.  Among those, only linetype and lineweight are part of the settings for Layers.
Kent Cooper, AIA
Message 11 of 17
kristiL539J
Sir our terminology is very different. I was asking about the width of the lines once they are plotted. Thanks! I will just make a new pen .ctb file.
Message 12 of 17
kristiL539J
I can't find the answer  to this problem! I will have to make a .ctb file🙃
Message 13 of 17
kristiL539J
When I first started this job, they were using the monochrome.ctb when they plot and also having
  Thicknesses assigned to their layers………….
I will just make our own .ctb file……Thanks
Message 14 of 17
TomBeauford
If you liked how the CTB file you used in 2018 worked why not use the same one?
Please don't tell me you don't have it anymore and will never be able to plot any of those older drawing properly again.
You would have had to share it with anyone you shared the drawing with for them to be able to plot it correctly.
Might be worth considering using Autodesk-MONO.stb instead that allows you to set layers to plot Black, Color, or one of 9 grayscales. As it's installed with AutoCAD you never have to worry about loosing it or sharing it with others as they would already be able to plot your drawings correctly.
2023
Message 15 of 17
Kent1Cooper
@kristiL539J wrote:
.... they were using the monochrome.ctb when they plot and also having Thicknesses assigned to their layers………….
Again:  lineweight, not thickness.
Kent Cooper, AIA
Message 16 of 17
kristiL539J
I will try this and see how it comes out! Thanks
Message 17 of 17
Kent1Cooper
@Kent1Cooper wrote:
....  What you're talking about is lineweight ....  Thickness is up off the page, in the Z direction.  Width is a characteristic of Polyline segments.  ....
All drawn on the same plane:
With CTB plotting, lineweight as plotted = difference in color on-screen, but Polyline width will ignore that.
Kent Cooper, AIA
