Set Default Hatch Layer - System Wide
PLANacass
PLANacass
I'm using CAD 2026.  Currently, with each new file I work in, whenever i use the command HATCH AutoCAD will create a new layer called "_dsg hatch".  I then have to change the hatch layer and purge the new layer that AutoCAD created.  How can I change the default layer that the command uses, system wide, so it doesn't create new layers that I have to purge?
DGCSCAD
Set the variable HPLAYER to "." (just a period).
AutoCad 2018 (full)
Win 11 Pro
PLANacass
Excellent, thank you.  So far this seems to have worked
Kent1Cooper
.... not only in existing drawings, but also in all your drawing template files, so it will be set in all new drawings.
Kent Cooper, AIA
DGCSCAD
You could also make it permanent by adding that^/this line to an ACADDOC.lsp file: (setvar 'HPLAYER ".")
First, test to see if you already have an acaddoc.lsp by copy/pasting this to the command line: (findfile "acaddoc.lsp")
If it returns a path and file, then add the (setvar 'HPLAYER ".") line to the existing file.
If it returns nil, then:
  • Create a new folder.
  • Create a new text file in that folder called acaddoc.lsp.
  • Copy/paste (setvar 'HPLAYER ".") into the new file, then save and close.
  • Go to OPTIONS in AutoCAD.
  • Add that new folders path to the "Support File Search Path", and "Trusted Locations".
Now, every drawing you open will have your HPLAYER variable set to a period.
You'll also have the ability to add other changes to various variables and such. You'll have opened a new world of automation for yourself.
AutoCad 2018 (full)
Win 11 Pro
