Attribute block not shown
avinash00002002
avinash00002002
I have attached drawing in that drawing two drawings named dwg-1 and dwg-2. int dwg-1 not shown attricute block named *U11 is not shown.
please suggest.
Avinash Patil
Alfred.NESWADBA
I would say there are no block-insertions at the end of the leader lines.
Why do you think that there should exist any block-insertions there?
To verify:
  • all layers are on and thawed
  • ANNOALLVISIBLE is set to 1
  • <CTRL><A> to select all does not show any geometry at the end of the leader lines
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
  • You have a block with annotation scale that can be turned off/on . So ( as alfred said ) "Why do you think that there should exist any block-insertions there?" [Click on below image]
  • A block named with an asterisk and a "U" (like *U18) in AutoCAD is known as an Anonymous Blocks. These are blocks without a user-assigned name. They are automatically generated by AutoCAD to support features like dynamic blocks, hatch patterns, tables, or associative dimensions. You normally can't use AutoCAD block editing commands with anonymous blocks.
Examples of anonymous blocks:
  • *U### - general anonymous blocks
  • *E### - anonymous blocks from non-uniformly scaled blocks - when exploded (e.g. solids, regions)
  • *D### - anonymous dimensions (dim blocks)
  • *X### - anonymous hatches (hatch blocks)
  • *A### - anonymous groups, DGN linetype blocks
  • *T### - anonymous blocks in tables
  • *S### - anonymous blocks of 3D views
My suggestion is to redefine the block you're using correctly. Afterward, you'll find your problem is automatically resolved.
Imad Habash
illusionistNUGXG
after renaming the block,
you should allways use ATTSYNC (outside of the block editor) on the block, after you changed anything inside...if the block contains an attribute. If you don't, changes usually don't apply.
rosie_lucas1
Hello @avinash00002002 ,
Just checking in—did the responses shared by @Alfred.NESWADBA, @imadHabash and @illusionistNUGXG help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie| Community Manager
