set autocad to open my default excel file template
luca.primicerio
luca.primicerio
Community Visitor
Community Visitor
HI!
is it possible to export with command "DATAEXTRACTION" the blocks attribute on my excel file predefinied?
I need to put the data extraction in a file excel with the header of my factory.
can i do that in automatic mode setting my template as default? Or everytimes, i have to copy the data extraction from excel file generated by autocad on my excel template?
thanks,
Luca.
john.vellek
HI @luca.primicerio,
Have you considered a datalink from AutoCAD to Excel?  I would like to test how well this would work for you. Do you have a sample file and dataextraction that I can look into? I would also like to see a sample "FINAL" excel file too.
John Vellek
john.vellek
Hi @luca.primicerio
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit. I am still happy to investigate this further if you share some sample files.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
