AutoCAD Forum
set a paper color
18 REPLIES 18
Message 1 of 19
c_ly0745K37
1580 Views, 18 Replies
set a paper color
I am developing a card at the moment that would be used on phones at night.  I then want to give it a dark background color when exporting to PDF so as not to harm the eyes.
I tried to define a fill color that matched the size of my paper and put it in the background, but this solution is buggy.  Several layers disappear leaving me a pdf with only (or almost) only the fill color.
Do you have a solution?  I thank you warmly.
18 REPLIES 18
Message 2 of 19
imadHabash
in reply to: c_ly0745K37
Try HATCHTOBACK (Command) and see if any changes .
Imad Habash
Message 3 of 19
c_ly0745K37
in reply to: imadHabash
This is already a solution that I have tried without success.
Message 4 of 19
imadHabash
We will give more help if you can attache here your CAD dwg file for testing .
Imad Habash
Message 5 of 19
RSomppi
Try restricting the hatch so that none of it coincides with the other objects.
Message 6 of 19
pendean
It is often not enough to send stuff back, you also have to bring stuff forward: explore all the many options in DRAWORDER command in AutoCAD's HELP, I'll get you started here
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-3DC76D6E-8F81-4803-8D0A-AA7541D6357E
Message 7 of 19
c_ly0745K37
I don't really see how to do it, I'll send you the attached file
Message 8 of 19
pendean
What is disappearing please? See attached PDFs from your files
Message 9 of 19
wispoxy
The default PublishToWebsite PNG.pc3 driver Properties > Custom Properties > Background Color > Select Color, then convert PNG to PDF. You'll need to create some custom paper sizes for the PNG driver that convert inches to pixals though.
Message 10 of 19
c_ly0745K37
Hinnn ??
How did you do that?  ha ha, when I export on my side, I get this
Message 11 of 19
wispoxy
Ok that's funny 🤣
Message 12 of 19
pendean
@c_ly0745K37 wrote:
Hinnn ??
CAD file showing you "how" to follow along with the instructions above was posted, start there.
HTH
Message 13 of 19
c_ly0745K37
in reply to: pendean
What file are you referring to?
Message 14 of 19
pendean
Scroll up to #8
Message 15 of 19
c_ly0745K37
problem solved, I changed High Quality Print to DWG to PDF
Message 16 of 19
pendean
Can you explain please? Your shared DWG file was already set to do that
Message 17 of 19
wispoxy
If what you said is true, the problem wasn't with the .dwg it's your .pc3 file and it varies per user default changes. High Quality Print.pc3 and DWG to PDF.pc3 are mostly the same output settings especially the color by default unless you changed it. The default for paper color of both is white.
You didn't mention you changed the default driver settings for your DWG to PDF.pc3 local driver. Really it works with High Quality Print.pc3 too if you match the driver settings. 😴
Tags (2)
Message 18 of 19
c_ly0745K37
in reply to: wispoxy
Yes, my file was set to high quality.  I changed it to DWG to PDF and there were no more presentation errors when exporting the document.
Yes, my paper remains white, it is the color of the hatching that I placed in the background which makes my paper color, for a document which will probably never be printed, but only consulted on the telephone.
Thank you for your help anyway.
Message 19 of 19
wispoxy
I understand you used a hatch, but they should have been the same. Maybe redownload the default High Quality Print.pc3 or match the settings to DWG to PDF.pc3.
AutoCAD Inside the Factory
