Send help, No x,y axis, can't zoom all i see is the red lines
jexo.dokyungsoo1127
jexo.dokyungsoo1127
CodeDing
@jexo.dokyungsoo1127 ,
Hopefully you aren't delivering to clients like this 🤔
CodeDing
Can you post the drawing for us to look at?
Valentin_CAD
Try these suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
imadHabash
You may need to turn OFF hardware acceleration.
Imad Habash
Michiel.Valcke
When you type the command GRAPHICSCONFIG, are you using virtual device DirectX11 or DirectX12?
If it says DirectX 11, try changing the system variable GFXDX12 to 0 and restart AutoCAD.
Otherwise try to turn the Hardware Acceleration of to see if it is a graphic card/driver issue. (if it works better without hardware acceleration, look to update your graphic card drivers)
