How do i remove unwanted and old printers from my plotter settings?
Sidney_Barrett-redford
Hi all,
Please see the below, my issue is I only use 2 or three of the printers below, and id like to remove the unwanted ones.
how do i do this?
thank you
cadffm
Without .pc3 extension:
They are installed in Windows!
With .pc3 extension:
Delete .pc3 files from your drive
Command: PlotterManager
WinExplorer open with the right folder current.
Sebastian
paullimapa
Which of these do you only use?
Paul Li
IT Specialist
@The Office
Valentin_CAD
@Sidney_Barrett-redford ,
These may help:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
pendean
Community Legend
Community Legend
@Sidney_Barrett-redford Ask your IT how to remove these from your list
If you find this setting in OPTIONS command unhelpful
And you control deleting these from PLOTTERMANAGER command in your AutoCAD if your CAD/IT Manager allows it
HTH
