Selection is not active after anymore after (MOVE, STRETCH,...)
Message 1 of 11
Hello.
I have a problem. After i stretch or move some line or object it will deselect itself. I want it to stay selected.
I have created a video.
On PC1 i have this problem.
On PC2 object stay selected.
How can i change that on PC1.
Here is video:
Replies (10)
Message 2 of 11
rkmcswain
Interesting, here is someone who *wants* the grips to go away after an edit. Do you get anything on the command line at the moment you stop grip editing? Like maybe a *Cancel* ?
Message 3 of 11
No i get no cancel or anything. The same on both computer.
Message 4 of 11
pendean
Community Legend
Community Legend
What is your exact version of AutoCAD? Post what ABOUT command lists.
Are you using core commands, or a customization?
Do you have add-ins installed?
Is this a sudden new problem? Or have you been suffering in silence for years?
What changed recently?
An office full of users here and none of us can replicate your issue t all today or in the past.
Message 5 of 11
rkmcswain
If it is a system variable, you can find it like this:
  1. Run the command SYSVDLG
  2. Click the button that says "Save All..."
  3. Give it a file name
  4. Repeat steps 1-3 on the other "good" machine.
  5. Open each exported file you made (using Notepad)
  6. Go to http://www.diffchecker.com
  7. Copy and paste the contents into the two fields on the website.
  8. Click "Find Difference"
Now you have all the differences between the two systems.
Of course you could also simply import the sysvar file from the good system into the bad system, at the risk of changing variables that you do not want to change.
Message 6 of 11
I have try SYSVDLG from computer where everything works. Then save to file and import to computer where this is not working.
And no luck.
I have autocad civil 3d 2013 and 2014 version. I don't have licence for newer one. Problem is on both version on the PC. I have also try another mouse. Reinstall logitech software for mouse.
I have try everything and i could not fix this. I guess it will be easyer to just reformat PC and install everything from new.
Message 7 of 11
dbroad
Yeah,  the nuclear option is always my first choice to fix something that is wasting a microsecond. Smiley Wink
On topic though, I've never found that a set of objects stays selected after a command is finished.  That is why the Express Tools MOCORO command was added.  Perhaps you have a customized situation, using reactors, that keeps objects selected on that one machine.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 11
pendean
Community Legend
Community Legend
Message 9 of 11
rkmcswain
And no luck.
I did not think it was a sysvar, and now you've ruled that out.
No reason to do something destructive. Start by manually resetting the user profile, as explained here. I have resolved many issues by doing this for users and it does not take long.
Message 10 of 11
rkmcswain
@DBROAD - did you watch the video and try it yourself? Gripped objects DO stay selected after a grip editing command is completed. That is the whole point of this post, his do not (on one workstation).
Message 11 of 11
dbroad
Thanks @rkmcswain.  No I hadn't watched the video just the subject line and text.  I still think it's something more likely to do with a customization gone wrong.   For example, here is a simple code that accomplishes that behavior:
;;load and watch your grips disappear after each grip command.
(if (not gripsclear)
(setq gripsclear
(VLR-Command-Reactor
nil
'((:vlr-commandended . clearsel))
(defun clearsel (r cl)
(sssetfirst nil nil)
;;To disable that behavior use CLEARSTOP command as defined by
(defun c:clearstop ()
(if gripsclear
(vlr-remove gripsclear)
(princ)
;;To start that behavior again use CLEARGRIPS as defined by
(defun c:cleargrips ()
(if gripsclear
(vlr-add gripsclear)
(princ)
