I'm having an issue which I think is GPU related but I'm not 100% sure. Lately my ACAD has been really laggy and stuttering a lot and my selection effect hasn't been working dashed lines instead of blue. I found it to an issue with hardware acceleration being turned off due to GPU issues but can't fix the issues through obvious means eg driver updates and wondered if anyone else can offer advice. My current card is a RTX A2000, which notably I can only find the laptop variant on the approved hardware list, but that may be me not understanding how the information is presented.
Switch off Hardware Acceleration and / or set 2D Display Settings to Basic Mode. (GRAPHICSCONFIG)
Have you tried installing the drivers from this link: https://www.autodesk.com/support/system-requirements/certified-graphics-hardware/autocad
It says desktop and notebook.
I'll give it a go, it is an older drive than what I have currently installed, will be a couple hours before I come back to this due to other commitments
Frustratingly, this wasn't the answer. If you can think of anything else that would be appreciated, thanks for trying.
Please see attached, my new working theory is its a windows issue considering the OS isn't displaying the system spec properly.
Thanks for the screenshots. This is why your ARCH2023 is sluggish
The program has downgraded to cope with your hardware/GPU driver being knocked out.
Are you on a laptop by chance?
@samuelb8Y56V wrote:
Laptop no, and according to task manager GPU (RTX A2000) is "alive".
But your AutoCAD thinks differently, and that's the problem
OR... Here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help (you can schedule an appointment and they can get into your PC):
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
