Selection Cycling Help
Hello I dont know what happened but I started having this problem and i dont know how to fix it , when I select something that its overlay it appear like this and it dosent show what im selecting
imadHabash
This is SELECTIONCYCLING  system variable issue . you may need to turn it OFF either by changing the system variable to  0  or by Ctrl+w OR by pressing the button below ( see the image ) . also you can choose between overlapping objects by pressing Shift+Space .
Imad Habash
Thanks for answering , the this is that I like the selection cycling because i can see what im selecting , but I dont know what happened that it dosent show what I select it just appear without the name of what im selecting
imadHabash
>>  but I dont know what happened that it dosent show what I select it just appear without the name of what im selecting <<
This is how it's work . when the dialog appear you have to select ( with mouse ) what overlapped item that you want to select . just select your needed item from the dialog .
Imad Habash
neaton
Can you attach the dwg file? Is it only those objects that don't show in selectioncycling or does it do it for any elements in the drawing?
Nancy
I know how to use it the problem is that it used to be like this ( first photo ) and then one day it started aperring like this ( second photo ) it dosent show the name or anything , I already reinstalled autocad and still appearing the problem , its not just only on one file even in the new ones this error continue apperring
