Selection Cycling Help
No aplicable
Hello I dont know what happened but I started having this problem and i dont know how to fix it , when I select something that its overlay it appear like this and it dosent show what im selecting
0 Me gusta
Responder
418 Vistas
5 Respuestas
Respuestas (5)
imadHabash
This is SELECTIONCYCLING  system variable issue . you may need to turn it OFF either by changing the system variable to  0  or by Ctrl+w OR by pressing the button below ( see the image ) . also you can choose between overlapping objects by pressing Shift+Space .
Imad Habash
0 Me gusta
No aplicable
Thanks for answering , the this is that I like the selection cycling because i can see what im selecting , but I dont know what happened that it dosent show what I select it just appear without the name of what im selecting
0 Me gusta
imadHabash
>>  but I dont know what happened that it dosent show what I select it just appear without the name of what im selecting <<
This is how it's work . when the dialog appear you have to select ( with mouse ) what overlapped item that you want to select . just select your needed item from the dialog .
Imad Habash
0 Me gusta
neaton
Can you attach the dwg file? Is it only those objects that don't show in selectioncycling or does it do it for any elements in the drawing?
Nancy
0 Me gusta
No aplicable
I know how to use it the problem is that it used to be like this ( first photo ) and then one day it started aperring like this ( second photo ) it dosent show the name or anything , I already reinstalled autocad and still appearing the problem , its not just only on one file even in the new ones this error continue apperring
0 Me gusta
