AutoCAD Forum
Selecting Objects with a Crossing Line and change properties
11 REPLIES 11
Message 1 of 12
RupinderWilkhu
543 Views, 11 Replies
RupinderWilkhu
How do I select objects using a line and then change the colour or other properties of the objects selected?
I'm tried the Select > F to draw a line across objects to select. But this doesn't highlight the properties for me to change?
Any advise or other trick?
11 REPLIES 11
Message 2 of 12
imadHabash
in reply to: RupinderWilkhu
imadHabash
I don't know what do you mean by " with a Crossing Line " .. But there is an express tool called Fast Select that you can use and see if it's help .
Imad Habash
Imad Habash
Message 3 of 12
RupinderWilkhu
in reply to: imadHabash
RupinderWilkhu
thanks but we have lots of objects at different elevations and directions hence drawing a line to then use FS will be just as long as selecting the objects manually.
If possible, I'd like to drawing a line on Select prompt...similarly to the below but then allow me to change the properties of the selected objects.
https://www.cadtobim.com/object-selection.html#:~:text=Selecting%20Objects%20with%20a%20Crossing%20L....
Message 4 of 12
cadffm
cadffm
what version are you using? Since Version 2011 the default setting for Select command is to select&highlight the result.
Variable: PICKADD=2
Try it again with object selection method F(ence), while pickadd is set to 2
Sebastian
Variable: PICKADD=2
Sebastian
Message 5 of 12
RupinderWilkhu
in reply to: cadffm
RupinderWilkhu
Nope! that didn't work
Message 6 of 12
cadffm
cadffm
So your Pickadd is set to 2?
You can use Select command AND you can select whatever (see 'Select' feedback? while and after you ended the command - see Textscreen [F2])
Is ther 0 found or 1 and more found - message?
Sebastian
Sebastian
Message 7 of 12
RupinderWilkhu
Brilliant...that's worked. Many thanks
Message 8 of 12
cadffm
cadffm
Simple way to show us what you trying to do:
Share a simple sample .dwg with a hand full objects in one color,
just some objects in question in another color, which one you want to select.
Simple way to show us what/why object selection method fence doesn't work,
share a screencast
I am sure we can help you, but first we need to be clear about what you need and why something is not currently working.
Sebastian
share a screencast
Sebastian
Message 9 of 12
cadffm
cadffm
What works?
Sebastian
What works?
Sebastian
Message 10 of 12
RupinderWilkhu
Changed Pickadd to 2 and then using Select > F > draw line through objects to select...allows me to change the properties of the selected objects
Message 11 of 12
cadffm
in reply to: cadffm
cadffm
ah okay, 👍
I missunderstood the first reply. RupinderWilkhu Nope! that didn't work
@cadffm wrote:
Hi, what version are you using? Since Version 2011 the default setting for Select command is to select&highlight the result.
Variable: PICKADD=2 Try it again with object selection method F(ence), while pickadd is set to 2
Glad to help
Sebastian
ah okay, 👍
Glad to help
Sebastian
Message 12 of 12
cadffm
cadffm
FYI - it was possible  before also (But I wanted to restore the default behavior for you first)
After Select->f like after every other time and way you selected object,
you can access the last selection set by selection method P / Previous selectionset
In Properties palette, press the button to add object seelction
and select the previous selection by type in
P<enter><enter>
or in copy move and other commands, doesn't matter how the object selection way made
Sebastian
P<enter><enter>
Sebastian
AutoCAD Inside the Factory
