AutoCAD Forum
Selecting objects by color doesn' work if the object's color is "by layer"
2 REPLIES 2
980 Views, 2 Replies
I'm trying to select objects by color but it doesn' work neither using Quick Select nor Filter if the object's color is "by layer".
Any way to solve this issue?
2 REPLIES 2
Alfred.NESWADBA
select objects with "Color = byLayer" and "Layer = ...." (the layers which have the color you are looking for.
There is no direct way (without development or a bit LISP).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
It works for me.
Thanks a lot.
Forma Design Contest
AutoCAD Beta
