Selecting components, tables and texts issues
daniel_hernandezEGPKS
Message 1 of 9
Hi community,
Somebody had have this issue with AutoCAD? (See image attached)
When I´m working and I try to select, tables, components, text and everithing looks like a dotted lines. I would like to know how I can to fix it.
Replies (8)
Message 2 of 9
user181
Maybe it is the variables SELECTIONEFFECT and PRESELECTIONEFFECT.  Type them at command line and make sure they are set to 1
Message 3 of 9
Thanks for sharing, but I already check those commands and the issue was not solved. In fact when I try to trim as well just appears one dotted line, and before this worked as a rectangle form to trim.
Please see attached images.
Message 4 of 9
pendean
Community Legend
Community Legend
@daniel_hernandezEGPKS For dotted line issue, set your GFXDX12 to zero, restart AutoCAD, then try again.
For TRIM command not giving you window selection: are you just fighting the TRIMEXTENDMODE variable setting by chance?
Are you using a 3rd party add-on?
Accidentally trigger FENCE selection method?
Not sure how one is related to the other, why the change of question?
Message 5 of 9
paullimapa
Did you recently started experiencing this problem with an updated AutoCAD version?
Enter About command, do a screenshot and share that here.
It looks like your graphics driver is not compatible with AutoCAD.
Enter command GraphicsConfig, do a screenshot and share that here also.
Paul Li
IT Specialist
@The Office
Message 6 of 9
Hi Paul,
I appreciate much your support. Here the screnshots.
Message 7 of 9
paullimapa
Looks like you do have the latest updates of 2024LT installed.
But something is not right with your graphics.
Try at command prompt enter the following:
GFXDX12
0
(that is a zero) and then restart LT.
Now enter command GraphicsConfig and see if you have the option under 2d Display Settings to change to different modes like Advanced, Intermediate & Basic.
Paul Li
IT Specialist
@The Office
Message 8 of 9
Thanks a lot for sharing everyone!
The issue was solved with this porocess.
Message 9 of 9
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
