- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm looking here for a function in AutoCAD to use the live-section function mutiple times in viewports. Or is there any other function available to create associative section views from a 3D model in a layout. Ideally with descriptions and section lines in a top view. But I would be happy to get only the section views automatically.
I have done some research already and I know the command VIEWBASE, the function SECTIONPLANE and LIVESECTION, but both is not suitable for my use case:
- VIEWBASE: At first, this function is what I need. But this function is not sufficent for my use case in construction, as well as for bigger models. An by using this function the file sizes increases by factor 7.
- SECTIONPLANE: I don't want to create 2D-Sections in my model space. That's not practicable. And finally these sections are not even associative.
- SOLVIEW/SOLDRAW: I also came across the functions SOLVIEW and SOLDRAW, but both isn't suitable either.
Has anyone an idea? Maybe is there a plugin available? Or ist this really all AutoCAD can do?
I have done also some online research before, but I haven't been successful so far.
My current solution: Using 3DCLIP and SECTION command, a lot of manually time consuming work but the best I know so far.
By the way, I'm using AutoCAD 2026.
