AutoCAD Forum
script code
5 REPLIES 5
428 Views, 5 Replies
script code
Hi, All...
How to write a simple script that loads lisps from a network location
without adding it is in the startup suit. (location is added in support file search path) Can anyone help me out with that?
my drive---T
Path-----Documents \my folder\Lisps
Lisp-------etr.lsp
comand----(defun c:Etr ()
I already added T drive in support directory
can anybody help me to solve this
5 REPLIES 5
rkmcswain
Do you want to load multiple lisp files at startup?
If so, create a file named "Acaddoc.lsp" and place it in the TOP support file seach path
;;example
(load "mylisp")
(load "yourlisp")
; the next one is not in the support file search path
(load "\\\\server\\share\\location\\another_lisp")
 If you are wanting to load one at run time, say from a menu macro... then...
^c^c(if (not c:myfunc)(load "myfunc"))myfunc;
R.K. McSwain     | CADpanacea | on twitter
in reply to: rkmcswain
Thanks for your reply...
but am using autoscript for working on multiple dwgs
so i need to get script language for call a lisp (am not good in lisp)
in this case how i can use your code
rkmcswain
What is autoscript?
Moshe-A
Save the following two lines to script file  <YourName>.scr
(load "t:\\Documents\\my folder\\Lisps\\etr.lsp")
ETR
but be aware that if the last code line in the lisp is:  (c:etr)
you do not need the second line
cheers
Moshe
in reply to: Moshe-A
Hi Moshe..
Thanks ... for ur support
It is running
Tdkhtr
AutoCAD Inside the Factory
