AutoCAD Forum
Screen resolution
7 REPLIES 7
Message 1 of 8
Alasdair1
3758 Views, 7 Replies
Screen resolution
Windows 10 settings gives me resolutions of 100% 125% etc etc. With Autocad 2019 on my screen the ribbon size is very small. Is there any way the ribbon can be zoomed without the changing the system settings, My Screen is an IIyama XB3070WQS.
7 REPLIES 7
Message 2 of 8
Mark.Lancaster
in reply to: Alasdair1
@Alasdair1
This is not an installation and licensing issue.  This is an  AutoCAD workflow/setting.  I will have the moderator relocate your posting to the AutoCAD forum
Mark Lancaster
Message 3 of 8
While it's waiting to get moved over to the AutoCAD folder:
What do you have here?
display settings.PNGAlso what do you have for a video card?
Mike Davis
Message 4 of 8
Alasdair1
in reply to: mdavis22569
If I move to 125% which I have in the past it makes all programmes bigger. Not what I want. In Excell I can zoom in and out I was wondering if the Ribbon in AutoCAD had the same facility. From what I gather it is fixed at 100% or 125% etc etc.
Message 5 of 8
mdavis22569
 it's fixed to a point ...
However what do you have for all of the settings?
Also what video card do you have?
Mike Davis
Message 6 of 8
Alasdair1
Nvidia G Force GTX 750i. The screen is set to 100%.
Message 7 of 8
pendean
change your monitor resolution from 2560 x 1600 to 1900 x 1080, does that do it for now?
Message 8 of 8
Alasdair1
in reply to: pendean
I have now found the best solution is to change the screen resolution to the 125% setting. The recommended setting is 100%. The resolution setting suggested did not work. Will run with 125%. Thanks for your help.
Forma Design Contest
