Screen not updating correctly
Often when I move an object to a another position, the screen is not updated, such that the object in question is visible in both it's new and old positions. Only after a regen the screen is updated correctly.
I am using AutoCAD MEP 2015, with graphics board Nvidia Quadro 4000. I updated the driver as per Autodesk recommendation to NVIDIA Driver Release - Quadro/Tesla Desktop - 331.82 64bit [9.18.13.3182].
The problem persists after update.
Alfred.NESWADBA
try to disable hardware acceleration (command _GRAPHICSCONFIG) and see if the error again appears.
Also make sure your AutoCAD is fully updated (best is to start Autodesk Desktop App, login, wait a few minutes until the update list gets refreshed and then install the updates).
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
