I have installed AutoCAD 2018 Student's Version and I'm experiencing a Flickering issue when am zooming the drawing
Solved by john.vellek. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
welcome @Anonymous.autodesk.com!
Which operating system, which graphic card and which graphic card driver are you using?
One try (for now): turn off hardware acceleration (command _GRAPHICSCONFIG) and see if that gets better.
And when you have that dialog open (where you turn off hardware acceleration), please show us a screenshot.
- alfred -
I'm Using it on a Windows 10 64 bit, i7 4700 MQ @ 2.4GHz 8GB RAM running with a NVIDIA GT 740M Graphic
In fact, the flickering happens to be more when switching off Hardware Acceleration
AutoCAD does only see the Intel HD graphic card (which is not a good one for AutoCAD), but not the nVidia you listed as built in.
Disable your Intel HD (in the BIOS) so AutoCAD get's the nVidia gc.
- alfred -
Hello
0) +1 with Alfred !
1) Please try to run with :
HQGEOM = 0
2) Then if necessary with:
LINEFADING & LINESMOOTHING = 0
Regards, Patrice
Patrice BRAUD
Hi @Anonymous,
It does appear from your image that AutoCAD is using the incorrect graphics card.
Here is an article that might help in configuring your graphics card software to force the nVidia card to be used with AutoCAD.
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
