AutoCAD Forum
Screen Flickering on Zooming
9 REPLIES 9
Message 1 of 10
11051 Views, 9 Replies
I have installed AutoCAD 2018 Student's Version and I'm experiencing a Flickering issue when am zooming the drawing
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which operating system, which graphic card and which graphic card driver are you using?
One try (for now): turn off hardware acceleration (command _GRAPHICSCONFIG) and see if that gets better.
And when you have that dialog open (where you turn off hardware acceleration), please show us a screenshot.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 10
in reply to: Alfred.NESWADBA
I'm Using it on a Windows 10 64 bit, i7 4700 MQ @ 2.4GHz 8GB RAM running with a NVIDIA GT 740M Graphic
Message 4 of 10
In fact, the flickering happens to be more when switching off Hardware Acceleration
Message 5 of 10
Alfred.NESWADBA
AutoCAD does only see the Intel HD graphic card (which is not a good one for AutoCAD), but not the nVidia you listed as built in.
Disable your Intel HD (in the BIOS) so AutoCAD get's the nVidia gc.
- alfred -
Alfred NESWADBA
Message 6 of 10
braudpat
Hello
0) +1 with Alfred !
1) Please try to run with :
HQGEOM = 0
2) Then if necessary with:
LINEFADING & LINESMOOTHING = 0
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 7 of 10
john.vellek
Hi @Anonymous,
It does appear from your image that AutoCAD is using the incorrect graphics card.
Here is an article that might help in configuring your graphics card software to force the nVidia card to be used with AutoCAD.
John Vellek
Message 8 of 10
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 9 of 10
in reply to: john.vellek
Hey! I changed my default Graphic card in control panel to nVidia!
And rebooted the Laptop and got it perfectly working
Viswanathan Sridhar
9884073709
Message 10 of 10
Viswanathan Sridhar
9884073709
AutoCAD Inside the Factory
