scale pop up window
scale pop up window
maramuresul
scale pop up window
maramuresul
hi,
how can i make to get SCALES pop up window, everytime i select dimension, text, multileader etc. ?
thank you
Andrei
imadHabash
your question still not clear yet.. would you give us a little pit more info please?
Waiting...
Imad Habash
maramuresul
hi,
When i select Dimensions, or Text or MultiLeader it usually appeared a window to choose scale. I want that window back.
I dont want to select from the bottom the scale with which i want to work. It was a pop up window that appeared instantly.
Thank you
RobDraw
It sounds like you are referring to Quick Properties.
Rob
