Field procedures can differ based on industry.  For example, in residential construction it would be common to "make it work", either through scaling or "guestimating" because minor variances rarely make a difference in the finished product.  In more rigorous engineered jobs though, they won't scale off a drawing.  They'll file an RFI (request for information) or similar document to get missing values.  That can impact schedules (the fabricator/constructor doesn't want to bill that to the client, so they pass it on to the engineering company) so you want to avoid that.  Similarly putting too many dimensions can also result in an RFI, as a collection of end-to-end dimensions may not agree with an overall dimension value (now they need to confirm which one is right), or a dimension may not precisely agree with what they are physically measuring.
While you don't need to dimension *everything*, all critical values necessary for fabrication and/or assembly (depending on the type of drawing) should be included so there are no such questions from the field.  That means taking steps such as letting non-critical dimensions "float" inside an overall dimension so there cannot be any conflicts, notes to ensure parts that need to fit existing spaces/objects are field measured prior to construction, and so on.
