Editing Default Command Settings
When running command "ATTACH" and then selecting an image, I want the check box "Insertion Point" > "Specify on screen" to be unchecked. How can I edit the template to change this?
chriscowgill7373
Mine seems to remember whatever the last setting utilized was and uses that when working in subsequent drawings.
I believe you have to set it, then successfully attach an item for it to hold.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
