AutoCAD Forum
Scale Bar
12 REPLIES 12
Message 1 of 13
1498 Views, 12 Replies
Scale Bar
As requested via Twitter, please could you provide me with screenshots for making adjustments to the scale bar properties. Many thanks
Tags (1)
12 REPLIES 12
Message 2 of 13
john.vellek
Hi @Anonymous,
Please give me an idea of what software you are running and which scalebar you are referring to. Is this one of the examples available from a tool palette?
John Vellek
Message 3 of 13
john.vellek
Hi @Anonymous,
I am checking back to see if you had resolved your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
Message 4 of 13
in reply to: john.vellek
Hi John,
No not heard anything yet. I was advised to post on here by the help desk Twitter account. They said they would send me screenshots of how to resolve the issue I have.
Many thanks,
Matthew
Sent from my iPad Pro
Message 5 of 13
TheCADnoob
Here is a gif i created for another thread showing how to create a scale and then set the scale.
CADnoob
Message 6 of 13
in reply to: TheCADnoob
Hi John,
Thanks for sending through the information, but this isn't what I am looking for. I need to know how I can edit the metric graphic scale that is found in the tool pallettes. It is set as cm but I need this to be in mm.
Matthew
Message 7 of 13
Alfred.NESWADBA
Can you please upload a screenshot of the position in your tool palette you are speaking about?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 8 of 13
TheCADnoob
is this the one you are talking about?
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
If so it looks like you have to used BEDIT.
CADnoob
Message 9 of 13
Hi John,
This is the one that I am talking about;
The default is in cm but I need to change this to mm.
Matthew
Message 10 of 13
Alfred.NESWADBA
Ok, you are speaking about AutoCAD Architecture, not plain AutoCAD.
That's another forum >>>there<<<.
- alfred -
Alfred NESWADBA
Message 11 of 13
Patchy
in reply to: Alfred.NESWADBA
mm bar scale, must be detailing a tiny little thing.
Message 12 of 13
john.vellek
Hi @Anonymous,
This is actually quite easy to do.
Open the Tool Palette (Annotation).
Rt-click on the Graphic Scale - Metric.
For Scale change the 1 value as needed such as to .1
Is this what you are looking for?
Another way to adjust it is to scroll down to the bottom where it says Custom Scale. You can select additional values there.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 13 of 13
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
AutoCAD Inside the Factory
