Scale Bar
Scale Bar
As requested via Twitter, please could you provide me with screenshots for making adjustments to the scale bar properties. Many thanks
Replies (12)
john.vellek
Hi @Anonymous,
Please give me an idea of what software you are running and which scalebar you are referring to. Is this one of the examples available from a tool palette?
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if you had resolved your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
Hi John,
No not heard anything yet. I was advised to post on here by the help desk Twitter account. They said they would send me screenshots of how to resolve the issue I have.
Many thanks,
Matthew
Sent from my iPad Pro
TheCADnoob
Here is a gif i created for another thread showing how to create a scale and then set the scale.
CADnoob
Hi John,
Thanks for sending through the information, but this isn't what I am looking for. I need to know how I can edit the metric graphic scale that is found in the tool pallettes. It is set as cm but I need this to be in mm.
Matthew
Alfred.NESWADBA
Can you please upload a screenshot of the position in your tool palette you are speaking about?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
TheCADnoob
is this the one you are talking about?
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
If so it looks like you have to used BEDIT.
CADnoob
Hi John,
This is the one that I am talking about;
The default is in cm but I need to change this to mm.
Matthew
Alfred.NESWADBA
Ok, you are speaking about AutoCAD Architecture, not plain AutoCAD.
That's another forum >>>there<<<.
- alfred -
Alfred NESWADBA
Patchy
mm bar scale, must be detailing a tiny little thing.
john.vellek
Hi @Anonymous,
This is actually quite easy to do.
Open the Tool Palette (Annotation).
Rt-click on the Graphic Scale - Metric.
For Scale change the 1 value as needed such as to .1
Is this what you are looking for?
Another way to adjust it is to scroll down to the bottom where it says Custom Scale. You can select additional values there.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
