I have recently begun to use the publish feature in Autocad and have had great results with PDF creation. The issue I am having is once a batch of PDF's are created I have to save each PDF individually to the destination folder. Is there a setting so that they save automatically without each one having to be addressed. It takes quite a while when saving a large number of PDF's. Any help on this matter would be greatly appreciated.
Solved by pendean. Go to Solution.
You're reply was somewhat helpful but the exact issue is that once the PDF's are generated the program opens the "save in" page and prompts me to navigate to the destination folder and then I have to save it to that folder manually. This takes a very long time if I have a large number of PDF's to make.
