AutoCAD Forum
Saved View issue
3 REPLIES 3
deltacoolguy
335 Views, 3 Replies
Saved View issue
I use Civil 3D, but this seems like a generic AutoCAD issue, so I am posting here.
We received a drawing from an architect.  I always do at least two saved views, "1" for an overall (not dview twisted) if I need to zoom back quickly, and "2" if I work in the drawing dview twisted, again so I can zoom back quickly.  I did that here when I received the file.
I work almost exclusively in view "2".  I go into paperspace and all is fine, but when I go back to modelspace it defaults back to view "1" (non-dview twisted)... every single time, no matter what the view rotation was prior.
I even tried starting a new drawing with a known template from our own office, inserted the architect's file, and got the same result.  Also tried working with UCS, etc.
I am attaching the Autocad file, if needed.  Please remember this file started elsewhere and I do not know what they did.  Thanks.
Edit:  I normally create saved views from the command line, not the dialog box, but I tried even that here.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
3 REPLIES 3
paullimapa
in reply to: deltacoolguy
when in model tab set UCSFOLLOW to 0
then your view 2 will stay even after going to 36x24 layout
Paul Li
IT Specialist
@The Office
deltacoolguy
in reply to: paullimapa
That did it.  Thank you.  🙂
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
