Ribbons are cut off at the bottoms
i cant seem to find out why my ribbons and layout tabs are cut off
vinodkl
Use the command "CUILOAD" and unload the ACAD CUI and again load it back by browsing. Does that fix the problem?
If not try updating your AutoCAD with latest update that might fix the issue.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Neither worked.
vinodkl
Try resetting your AutoCAD to defaults and see if that's fixes the issue. Here is how you can reset AutoCAD to defaults: How to reset AutoCAD to defaults
sophia_lee
hi@Anonymous
The reason for your issue is because the windows True Type font size is too big.
  1. Enter Windows + R
  2. type 'Font size' then you will see 'Make font size bigger'
  3. Set the Font size as default then you will see all the fonts from the Ribbon.
If you would like to have bigger fonts, don't change the setting for font only but also the general display scale setting from Display;
Kindly 'Accept as solution' if this answers your question. thank you
Sophia, Lee
Sr Technical Support Specialist
Customer Technical Success APAC
