AutoCAD Forum
Revolve, sweep, extrude?! through path
15 REPLIES 15
Message 1 of 16
joaoh261
708 Views, 15 Replies
I tried all the commands in the title but with no success. I'm trying to create a solid out of these lines. Basically the end result should look more or less like 1/4 off an egg.
I have a vertical polyline that i need to "revolve" around it's self but the outside (the arch) should follow the ellipse on the floor.
Captura de ecrã 2019-08-06, às 11.34.35.pngCaptura de ecrã 2019-08-06, às 11.25.59.png
15 REPLIES 15
Message 2 of 16
j.palmeL29YX
in reply to: joaoh261
Post your .dwg here and I will show you a video how to do what you want.
(sweep or loft and surfpatch and surfsculpt will do the job).
Jürgen Palme
Message 3 of 16
imadHabash
look at your Z direction on ucs icon , select the icon and rotate it to the direction that you want . any changes now ?
Imad Habash
Message 4 of 16
joaoh261
in reply to: j.palmeL29YX
Did you get the dwg file? I uploaded it but it looks like it got deleted I don't know why.
Message 5 of 16
joaoh261
in reply to: imadHabash
Sorry I don't get it
Message 6 of 16
imadHabash
as you can see in below image , the problem is that you have an ellipse with two different radius direction that your shape will follow ( dashed green and magenta ). if you have a circle path it will be done successfully because you're using one radius direction.  i think that it can be done by doing more than command procedure .
Imad Habash
Message 7 of 16
j.palmeL29YX
I'm not sure which result you expect. Here (attached) one model.
Jürgen Palme
Message 8 of 16
joaoh261
I'm using a 2015 version so I can't open the file. Do you mind saving it for an older version and uploading it again?
Also i'm on a Mac so Trueview doesn't work. Thank you
Message 9 of 16
joaoh261
I tried it before with a circle path and it works but that's not what I want. The problem i'm having is because i'm trying to use an ellipse, that's why I don't know how to do it.
Message 10 of 16
j.palmeL29YX
>> I'm using a 2015 version <<
Such "details" should be written i the initial posting. (tip for future postings)
Here in 2013 format attached.
Jürgen Palme
Message 11 of 16
imadHabash
i'm afraid not !!!
Imad Habash
Message 12 of 16
joaoh261
That's what I wanted. Do you mind explaining briefly how you did the top part? so I know for the next time.
Thank you very much really
Message 13 of 16
j.palmeL29YX
>> i'm afraid not !!!  <<
Here still some examples, trying to use a constant radius (15, 16, 17, 18, 19 and 19.9999) along the elliptical edge.
It is geometrical impossible to get ONE radius along the elliptical edge.
[EDIT]: ok, in the meantime I see that the suggestion above was accepted. THX
Jürgen Palme
Message 14 of 16
imadHabash
i was NOT talking about the way your resolve it ( it's perfect ) , i was talking about the revision of the file type no more . 🙂
Imad Habash
Message 15 of 16
j.palmeL29YX
>> Do you mind explaining briefly how you did the top part? <<
See this video.
HTH
Jürgen Palme
Message 16 of 16
joaoh261
Once again much appreciated.
Thank you!
AutoCAD Inside the Factory
