Hello, I'm trying to fill in the object with pattern and solid colors for rendering, but there's a thin white line appears around it which makes the fill looks incomplete. Also, the drawing lines' thickness is getting selected separately. Knowing that I have used many different ways of exporting the drawing and enhancing the quality and resolution in both programs but nothing works. Please if you have any sort of information don't hesitate to help me.
Thank you!
The process we use for editing drawings in Photoshop is:
1) Print to PDF using AutoCAD's High Quality print option (in versions 2016 and up). Under PDF Options... in the Plot dialog you can select additional quality and other options.
2) Drag the PDF into Photoshop (or use Photoshop's Open function) and input the import resolution you want.
If that's what you're doing and you're still having trouble, then you should upload a sample .dwg and .psd/.png that illustrates your problem for us to look at.
