Is there a way to figure out the status of the rename layout tab checkbox on the sheet set rename dialogue?
For example a system variable or a registry entry?
I need to be able to ensure this is unchecked by default, probably by way of a script.
G
Solved by dmfrazier. Go to Solution.
Brilliant - thankyou.
I suspected it might be in the registry as I couldn't find a system variable for it. full path (for Acad2019) is here if anyone else is interested:
Computer\HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R23.0\ACAD-2001:409\Profiles\SENL Standard Mobile\Dialogs\SSMNavigator
Bear in mind that individual "paths" will vary by product, version, and profile name.
